查看: 1250|回复: 0
【FPGA】Verilog状态机设计
    发表于 2021-3-16 22:33:57 | 显示全部楼层 |阅读模式
    状态机是fpga设计中极其重要的一种技巧,掌握状态机的写法可以使fpga的开发事半功倍。
    下面记录一下状态机的基本知识理论。
    实例:
    三种状态机实现代码:
    1. // 一段式状态机
    2. module style1_fsm(i_clk, rst_n, i1, i2, o1, o2, err);
    3. input i_clk, rst_n, i1, i2;
    4. output o1, o2, err;
    5. parameter [3:0] IDLE = 4'b0001,
    6.                 S1   = 4'b0010,
    7.                 S2   = 4'b0100,
    8.                 ERROR= 4'b1000;
    9. reg o1, o2, err;
    10. reg [3:0] state;
    11. always @(posedge i_clk or negedge rst_n)
    12. begin
    13.         if(!rst_n) begin
    14.                 state <= IDLE;
    15.                 {o1, o2, err} <= 3'b000;
    16.         end
    17.         else
    18.                 case(state)
    19.                 IDLE:        begin
    20.                                 if(!i1) begin
    21.                                         {o1, o2, err} <= 3'b000;
    22.                                         state <= IDLE;
    23.                                 end
    24.                                 if(i1 & i2) begin
    25.                                         {o1, o2, err} <= 3'b100;
    26.                                         state <= S1;
    27.                                 end
    28.                                 if(i1 & !i2) begin
    29.                                         {o1, o2, err} <= 3'b111;
    30.                                         state <= ERROR;
    31.                                 end
    32.                         end
    33.                 S1:        begin
    34.                                 if(!i2) begin
    35.                                         {o1, o2, err} <= 3'b100;
    36.                                         state <= S1;
    37.                                 end
    38.                                 if(i1 & i2) begin
    39.                                         {o1, o2, err} <= 3'b010;
    40.                                         state <= S2;
    41.                                 end
    42.                                 if(!i1 & i2) begin
    43.                                         {o1, o2, err} <= 3'b111;
    44.                                         state <= ERROR;
    45.                                 end
    46.                         end
    47.                 S2:        begin
    48.                                 if(i2) begin
    49.                                         {o1, o2, err} <= 3'b010;
    50.                                         state <= S2;
    51.                                 end
    52.                                 if(i1 & !i2) begin
    53.                                         {o1, o2, err} <= 3'b000;
    54.                                         state <= IDLE;
    55.                                 end
    56.                                 if(!i1 & !i2) begin
    57.                                         {o1, o2, err} <= 3'b111;
    58.                                         state <= ERROR;
    59.                                 end
    60.                         end
    61.                 ERROR:        begin
    62.                                 if(i1) begin
    63.                                         {o1, o2, err} <= 3'b111;
    64.                                         state <= ERROR;
    65.                                 end
    66.                                 if(!i1) begin
    67.                                         {o1, o2, err} <= 3'b000;
    68.                                         state <= IDLE;
    69.                                 end
    70.                         end
    71.                 default:begin
    72.                                 {o1, o2, err} <= 3'b000;
    73.                                 state <= IDLE;
    74.                         end
    75.                 endcase
    76. end
    77. endmodule
    1. // 两段式状态机
    2. module style2_fsm(i_clk, rst_n, i1, i2, o1, o2, err);
    6.                 S1   = 4'b0010,
    7.                 S2   = 4'b0100,
    8.                 ERROR= 4'b1000;
    9. reg o1, o2, err;
    10. reg [3:0] curr_state, next_state;
    11. always @(posedge i_clk or negedge rst_n) begin
    12.         if(!rst_n)
    13.                 curr_state <= IDLE;
    14.         else
    15.                 curr_state <= next_state;
    16. end
    17. always @(curr_state or i1 or i2) begin
    18.         case(curr_state)
    19.         IDLE:        begin
    20.                         if(!i1) begin
    21.                                 IDLE_OUT;
    22.                                 next_state = IDLE;
    23.                         end
    25.                                 S1_OUT;
    26.                                 next_state = S1;
    27.                         end
    29.                                 ERROR_OUT;
    30.                                 next_state = ERROR;
    31.                         end
    32.                 end
    33.         S1:        begin
    34.                         if(!i2) begin
    35.                                 S1_OUT;
    36.                                 next_state = S1;
    37.                         end
    38.                         if(!i1 & i2) begin
    39.                                 ERROR_OUT;
    40.                                 next_state = ERROR;
    41.                         end
    42.                         if(i1 & i2) begin
    43.                                 S2_OUT;
    44.                                 next_state = S2;
    45.                         end
    46.                 end
    47.         S2:        begin
    48.                         if(i2) begin
    49.                                 S2_OUT;
    50.                                 next_state = S2;
    51.                         end
    53.                                 IDLE_OUT;
    54.                                 next_state = IDLE;
    55.                         end
    57.                                 ERROR_OUT;
    58.                                 next_state = ERROR;
    59.                         end
    60.                 end
    61.         ERROR:        begin
    62.                         if(i1) begin
    63.                                 ERROR_OUT;
    64.                                 next_state = ERROR;
    65.                         end
    66.                         if(!i1) begin
    67.                                 IDLE_OUT;
    68.                                 next_state = IDLE;
    69.                         end
    70.                 end
    71.         default:begin
    72.                         IDLE_OUT;
    73.                         next_state <= IDLE;
    74.                 end
    75.         endcase
    76. end
    77. task IDLE_OUT;
    78.         {o1, o2, err} = 3'b000;
    79. endtask
    80. task S1_OUT;
    81.         {o1, o2, err} = 3'b100;
    82. endtask
    83. task S2_OUT;
    84.         {o1, o2, err} = 3'b010;
    85. endtask
    86. task ERROR_OUT;
    87.         {o1, o2, err} = 3'b111;
    88. endtask
    89. endmodule
    1. // 三段式状态机
    2. module style3_fsm(i_clk, rst_n, i1, i2, o1, o2, err);
    6.                 S1   = 4'b0010,
    7.                 S2   = 4'b0100,
    8.                 ERROR= 4'b1000;
    9. reg o1, o2, err;
    12. begin
    13.         if(!rst_n)
    14.                 curr_state <= IDLE;
    15.         else
    16.                 curr_state <= next_state;
    17. end
    18. always @(curr_state or i1 or i2)
    19. begin
    20.         case(curr_state)
    21.         IDLE:        begin
    22.                         if(!i1)                next_state = IDLE;
    23.                         if(i1 & i2)        next_state = S1;
    24.                         if(i1 & !i2)        next_state = ERROR;
    25.                 end
    26.         S1:        begin
    27.                         if(!i2)                next_state = S1;
    28.                         if(i1 & i2)        next_state = S2;
    29.                         if(!i1 & i2)        next_state = ERROR;
    30.                 end
    31.         S2:        begin
    32.                         if(i2)                next_state = S2;
    33.                         if(i1 & !i2)        next_state = IDLE;
    34.                         if(!i1 & !i2)        next_state = ERROR;
    35.                 end
    36.         ERROR:        begin
    37.                         if(i1)                next_state = ERROR;
    38.                         if(!i1)                next_state = IDLE;
    39.                 end
    40.         default:begin
    41.                         next_state = IDLE;        // 不加这个default项 输出会一直是000!!!
    42.                 end
    43.         endcase
    44. end
    45. always @(posedge i_clk or negedge rst_n)
    46. begin
    47.         if(!rst_n)
    48.                 {o1, o2, err} <= 3'b000;
    49.         else begin
    50.                 case(next_state)
    51.                 IDLE:        {o1, o2, err} <= 3'b000;
    52.                 S1:        {o1, o2, err} <= 3'b100;
    53.                 S2:        {o1, o2, err} <= 3'b010;
    54.                 ERROR:        {o1, o2, err} <= 3'b111;
    55.                 default:{o1, o2, err} <= 3'b000;//不加这个default 复位前信号都为不定值X
    56.                 endcase
    57.         end
    58. end
    59. endmodule
    GMT+8, 2026-4-28 16:25 , Processed in 0.712878 second(s), 37 queries .
