查看: 1201|回复: 0
Cygwin综合实现RISC-V出错
    发表于 2020-8-16 22:35:15 | 显示全部楼层 |阅读模式
    RISC-V的例子都要求在LINUX下安装VIVADO,比较麻烦,想在WINDOWS下用Cygwin试试
    1.打开cygwin,运行如下命令
    1. export PATH=$PATH:/cygdrive/c/Xilinx/Vivado/2015.2/bin
    2.从 github下克隆e200_opensource-master
    3.从digilent下载arty-a7-35的board file并放到\Xilinx\Vivado\2015.2\data\boards\board_files目录下
    4.切换目录并运行
    1. cd d:/e200_opensource-master/fpga
    2. make install CORE=e203
    5.将\e200_opensource-master\fpga\artydevkit\script中的board.tcl打开,将part_board做如下更改:
    1. set part_board {digilentinc.com:arty-a7-35:part0:1.0}
    6.生成bit文件
    1. make bit
    结果报错:
    1. ERROR: [Vivado 12-172] File or Directory '/cygdrive/d/e200/fpga/install/rtl/core/e203_ifu_ift2icb.v' does not exist
    2. INFO: [Common 17-206] Exiting Vivado at Thu Sep 13 11:10:16 2018...
    3. make[1]: *** [Makefile:18:obj/system.bit] 错误 1
    4. make[1]: 离开目录“/cygdrive/d/e200/fpga/artydevkit”
    5. make: *** [common.mk:41:bit] 错误 2
    但实际上该目录下确实是有e203_ifu_ift2icb.v的,百思不得其解。
    上一篇:RISC-V维基介绍,有参考(英文)
    下一篇:[FreeRTOS] Using FreeRTOS on RISC-V Microcontrollers
    GMT+8, 2025-1-11 02:01 , Processed in 0.528939 second(s), 46 queries .
