IAR Embedded Workbench for RISC-V supports RV32 and RV32E 32-bit RISC-V cores and extensions, including RISC-V P extension for Packed-SIMD instructions and RISC-V B extension. The support for custom extensions helps when working with designing custom cores with exact definitions for an application or a product.
IAR FOR RISC-V最新版本Latest version 2.11
Editor enhancements - Editor themes - a new way to set up the colors and fonts in the text editor
- Syntax feedback - instant syntax suggestions while typing
Device support Support for the following devices has been added: - NSITEXE NS31A
- Codasip L30, L30F, L50 and L50F
Additional Debug drivers - GDB Server
- Simplified Third Party Driver
IAR FOR RISC-V稳定版本Latest version 2.10.1
RISC-V standard extension Bit-manip (RV32B) - Assembler, simulator, and compiler support for the subgroups Zba, Zbb, Zbc, and Zbs from the RISC-V standard extension RVB
Andes V5 performance extensions - Assembler, simulator, compiler, and library support for Andes V5 performance extensions
Debug enhancements - For devices that support system bus access, the watch windows now support live update of variables
- Handling of different reset modes has been improved
Iarbuild enhancements The iarbuild command line build utility now supports: - Generating a Ninja build file based on the IAR Embedded Workbench project format
- Generating a JSON description of the Embedded Workbench project
- More C-STAT reporting and configuration methods
Improved Code Completion - Wider scope of assisted situations, for example when adding include files
- More information is shown with the suggestions, for example information on function parameters and types
- ’Fuzzy matching’ aids in identifying suggested completions
Device support Support for the following devices has been added: - Andes A27, A45, D45 and N45
- Fraunhofer EMSA5
64-bit Windows - IAR Embedded Workbench for RISC-V is now built for 64-bit Windows
Important information- Upgrade information
- Before you install
To avoid any problems, do not install this release in a directory where you have previously installed any older version of IAR Embedded Workbench. It is recommended that you either uninstall an earlier product, or install this release in a separate directory. As before, however, it is possible to install different products, all using the same version of the main application, in the same root directory. - License renewal
The upgrade to this version requires a license renewal. This can be performed by starting the IAR License Manager and selecting License→Check for License Renewal, or by using the Light License Manager with the command LightLicenseManager renew YOUR_PROD.EW.
- Microsoft SCC interface no longer supported
Microsoft SCC-compatible version control systems are no longer supported by IAR Embedded Workbench. - Microsoft Windows
Windows Vista and newer operating systems have a security mechanism called UAC (User Access Control). Disabling UAC will automatically grant you permission when a task requires administrative rights but this is not recommended because it will reduce the security of the computer. It is not necessary to run the IAR Embedded Workbench IDE as an administrator. However, if you are not, modifications to the installed product tree in C:\Program Files\IAR Systems might not work as intended and could give unexpected results. One example is opening and building projects directly from the installed product tree. The build will succeed, but the resulting files (object, list, ...) will not appear where expected. Instead all output files will be redirected by the OS to C:\Users\<user name>\AppData\Local\VirtualStore\Program Files\IAR Systems. To avoid this, the preferred way is to copy the examples to a location outside Program Files, either manually or automatically by opening them via the IAR Information Center.
- Known limitations
- C++ RTTI and exceptions are not supported by the compiler
The exception and interrupt catch functionality that can be enabled under Project>Options>I-jet>Breakpoints>Catch exceptions requires that the selected device has implemented triggers for instruction counter, interrupt catch, and exception catch. Consult the device vendor manual for details Flash breakpoints are not supported in this release #pragma vector and automatic population of an interrupt vector are not supported for all devices, and interrupt vectors must then be set up manually Some of the flash loaders included in this release are macro-based and are to be considered temporary. Until a flash loader executing in RAM is implemented, the performance with respect to download speed will be limited IAR Embedded Workbench for RISC-V is not ABI-compliant with the RISC-V specification, and linking with libraries compiled with gcc is not supported in this release The code generation for the B-extensions Zba, Zbb, Zbc, and Zbs is not fully optimized in this release
- Network licenses
For network licenses, IAR Embedded Workbench for RISC-V version 2.10.1 and later requires IAR License Server Tools version 2.18.2 or later. For more information, see technical note TN21842. The latest IAR License Server Tools are backwards compatible with previous IAR Embedded Workbench versions. - 64-bit Windows support
IAR tools such as the compiler and debugger now run as Windows 64-bit programs. 32-bit Windows is not supported. - Incompatibility with Embedded workbench for Arm 9.10.1
If Embedded workbench for RISC-V is installed after Embedded Workbench for Arm 9.10.1 (All other versions are fine) in the same installation directory and then uninstalled it will break the Arm installation. To fix this issue run the Embedded workbench for Arm installer again to repair the installation.
Trademarks
IAR Systems, IAR Embedded Workbench, Embedded Trust, C-Trust, IAR Connect, C-SPY, C-RUN, C-STAT, IAR Visual State, IAR KickStart Kit, I-jet, I-jet Trace, I-scope, IAR Academy, IAR, and the logotype of IAR Systems are trademarks or registered trademarks owned by IAR Systems AB. Microsoft and Windows are registered trademarks of Microsoft Corporation. Adobe and Acrobat Reader are registered trademarks of Adobe Systems Incorporated. CodeWright is a registered trademark of Starbase Corporation. All other product names are trademarks or registered trademarks of their respective owners.
IAR FOR RISC-V测试版本IAR FOR RISC-V V1.40.1
Supported devicesIAR Embedded Workbench for RISC-V supports RV32 and RV32E 32-bit RISC-V cores and extensions, including RISC-V P extension for Packed-SIMD instructions and RISC-V B extension.
