查看: 1386|回复: 0
RISC-V结构逻辑图
    发表于 2020-8-21 01:01:19 | 显示全部楼层 |阅读模式
    说明:
    执行6级流水作业:
    1. fetch(取指)
    2. decode(译码)
    3. dispatch/renaming(分发/重命名)
    4. select/wakeup(选择/唤醒)
    5. execution/mem access/finish(执行/存取/结束)
    6. complete/retire(完成/恢复)
    六级流水作业的另一种划分说法:
    The six-stage pipeline should be divided into the following stages:
    • Instruction Fetch (取指)-- request instruction from iMem and update PC
    • Decode(译码) -- receive response from iMem and decode instruction
    • Register Fetch(取寄存器) -- read from the register file
    • Execute(执行) -- execute the instruction and redirect the processor if necessary
    • Memory(存储) -- send memory request to dMem
    • Write Back(回写) -- receive memory response from dMem (if applicable) and write to register file
    设计完成后的芯片:
    1
    2
    GMT+8, 2026-6-15 16:24 , Processed in 0.283992 second(s), 37 queries .
