查看: 1050|回复: 0
即将到来的Linux 4.15内核中RISC-V被合并的git log
    发表于 2020-8-23 11:24:01 | 显示全部楼层 |阅读模式
    在这些天寒地冻,老司机也冻成狗的日子里,RISC-V和Linux的革命友谊发展迅猛,终于要在Linux 4.15内核胜利会师了。
    Linux 4.15 将支持加州伯克利开发的开源指令集架构 RISC-V,目前我们在Linus的tree的master branch上面已经看到risc-v的代码:
    相关的commit log如下,可以看出涉及的代码大概有2万行:
    pull发生在2017-11-15:
    This contains the core RISC-V Linux port, which has been through nine  rounds of review on various mailing lists. The port is not complete:  there's some cleanup patches moving through the review process, a  whole bunch of drivers that need some work, and a lot of feature  additions that will be needed.
    The patches contained in this tag have been through nine rounds of  review on the various mailing lists. I have some outstanding cleanup  patches, but since there's been so much review on these patches I  thought it would be best to submit them as-is and then submit explicit  cleanup patches so everyone can review them. This first patch set is  big enough that it's a bit of a pain to constantly rewrite, and it's  caused a few headaches with various contributors.
    The port is definately a work in progress. While what's there builds  and boots with 4.14, it's a bit hard to actually see anything happen  because there are no device drivers yet. I maintain a staging branch  that contains all the device drivers and cleanup that actually works,  but those patches won't all be ready for a while. I'd like to get what  we currently have into your tree so everyone can start working from a  single base -- of particular importance is allowing the glibc  upstreaming process to proceed so we can sort out any possibly  lingering user-visible ABI problems we might have.
    commit log显示,目前还缺乏大量的驱动,所以实际上"hard to actually see anything happen"。
    另外,目前的merge是"as is",这意味着后续还需要大量的cleanup工作。
    GMT+8, 2026-6-15 16:21 , Processed in 0.377342 second(s), 38 queries .
