查看: 634|回复: 0
【Arch Linux】安装 Nuclei Studio IDE 的 AUR 包
    发表于 2022-11-6 10:07:29 | 显示全部楼层 |阅读模式
    Nuclei Studio IDE 打包了 AUR 包,便于 Arch Linux 用户安装。连接:
    https://aur.archlinux.org/packages/nucleistudioide/
    nucleistudioide PKGBUILD 脚本
    1. # Maintainer: taotieren
    2. pkgname=nucleistudioide
    3. pkgver=202102
    4. pkgrel=9
    5. pkgdesc="Nuclei Studio IDE 是基于 MCU Eclipse IDE 开发的一款针对芯来公司处理器核产品的集成开发环境工具,用于 RISC-V 开发继承了 Eclipse IDE 平台的各种优势。"
    6. arch=("x86_64")
    7. makedepends=()
    8. depends=('nuclei-gcc' 'nuclei-openocd')
    9. optdepends=('jlink-software-and-documentation: Segger JLink software & documentation pack for Linux')
    10. conflicts=()
    11. url="https://www.nucleisys.com/download.php"
    12. license=('unknow')
    13. options=(!strip)
    14. source=("https://www.nucleisys.com/upload/files/nucleistudio/NucleiStudio_IDE_202102-lin64.tgz")
    15. sha256sums=('a005671317725f33e177d2ba9272cd77e0c04ef3d28c7cf8de4565c3f83b651e')
    16. package() {
    17.         cd "$srcdir"
    18.         msg2 'Installing Nuclei Studio IDE'
    19.         install -d -m755 "${pkgdir}/opt/nuclei"
    20.         tar zxf "NucleiStudio_IDE_${pkgver}-lin64.tgz"
    21.         rm -rf "NucleiStudio_IDE_${pkgver}/NucleiStudio/toolchain/openocd"
    22.         rm -rf "NucleiStudio_IDE_${pkgver}/NucleiStudio/toolchain/gcc"
    23.
    24.         mv "${srcdir}/NucleiStudio_IDE_${pkgver}/NucleiStudio" "${pkgdir}/opt/nuclei"
    25.         msg2 'Instalation of binary file'
    26.         install -Dm755 /dev/stdin "${pkgdir}/usr/bin/${pkgname}" <
    27. #!/bin/sh
    28. /opt/nuclei/NucleiStudio/NucleiStudio "\$@"
    29. EOF
    30.         install -Dm644 /dev/stdin "${pkgdir}/etc/udev/rules.d/99-nuclei.rules" <
    31. # Copy this file to /etc/udev/rules.d/
    32. # If rules fail to reload automatically, you can refresh udev rules
    33. # with the command "udevadm control --reload"
    34. # This rules are based on the udev rules from the OpenOCD project, with unsupported probes removed.
    35. # See http://openocd.org/ for more details.
    36. #
    37. # This file is available under the GNU General Public License v2.0
    38. ACTION!="add|change", GOTO="nuclei_rules_end"
    39. #SUBSYSTEM=="gpio", MODE="0660", GROUP="plugdev", TAG+="uaccess"
    40. SUBSYSTEM!="usb|tty|hidraw", GOTO="nuclei_rules_end"
    41. # [GNU MCU Eclipse] -----------------------------------------------------------
    42. # To simplify access, the access rights were changed from:
    43. #   MODE="660", GROUP="plugdev", TAG+="uaccess"
    44. # to:
    45. #   MODE="666"
    46. # -----------------------------------------------------------------------------
    47. # Please keep this list sorted by VID:PID
    48. # nuclei
    49. SUBSYSTEM=="usb", ATTR{idVendor}=="0403", ATTR{idProduct}=="6010", MODE="666", GROUP="plugdev"
    50. SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6010", MODE="666", GROUP="plugdev"
    51. LABEL="nuclei_rules_end"
    52. EOF
    53.         msg2 'Installing desktop shortcut'
    54.         install -Dm644 /dev/stdin "$pkgdir/usr/share/applications/${pkgname}.desktop" <
    55. [Desktop Entry]
    56. Name=NucleiStudioIDE
    57. Comment=NucleiStudioIDE
    58. GenericName=NucleiStudioIDE
    59. Exec=env GDK_BACKEND=x11 nucleistudioide %F
    60. Icon=
    61. Path=/opt/nuclei/NucleiStudio/
    62. Terminal=false
    63. StartupNotify=true
    64. Type=Application
    65. Categories=Development
    66. EOF
    67. }
    68. #
    69. # makepkg --printsrcinfo > .SRCINFO
    70. #
    71. # vim: set ts=8 sw=8 tw=0 noet:
    https://aur.archlinux.org/packages/nuclei-gcc/
    nuclei-gcc PKGBUILD 脚本
    2. pkgname=nuclei-gcc
    3. pkgver=2020.08
    4. pkgrel=1
    5. pkgdesc="nuclei-gcc 是 Nuclei Studio IDE 的编译工具。"
    6. arch=("x86_64")
    7. makedepends=()
    8. depends=()
    9. optdepends=()
    10. conflicts=()
    14. source=("https://www.nucleisys.com/upload/files/toochain/gcc/nuclei_riscv_newlibc_prebuilt_linux64_${pkgver}.tar.bz2")
    15. sha256sums=('398C25B9385B8122D2E864BF71E47B1D871F6C326C21D0AE6D3AFD2858F36041')
    16. package() {
    17.         msg2 'Installing Nuclei GCC'
    18.         install -dm755 "${pkgdir}/opt/nuclei/NucleiStudio/toolchain"
    19.         mv "${srcdir}/gcc" "${pkgdir}/opt/nuclei"
    20.         ln -sf "/opt/nuclei/gcc" "${pkgdir}/opt/nuclei/NucleiStudio/toolchain/gcc"
    21. }
    22. #
    23. # makepkg --printsrcinfo > .SRCINFO
    24. #
    25. # vim: set ts=8 sw=8 tw=0 noet:
    https://aur.archlinux.org/packages/nuclei-openocd/
    nuclei-openocd PKGBUILD 脚本
    2. pkgname=nuclei-openocd
    3. pkgver=0.10.0
    4. pkgrel=1
    5. pkgdesc="nuclei-openocd 是 Nuclei Studio IDE 的调试工具。"
    6. arch=("x86_64")
    7. makedepends=()
    8. depends=()
    9. optdepends=()
    10. conflicts=()
    14. source=("https://www.nucleisys.com/upload/files/toochain/openocd/nuclei-openocd-${pkgver}-15-linux-x64.tgz")
    15. sha256sums=('636E48FFBA7AB4B63F28F36DB2549C09FB04CD2F876E450B8C3E39AF4E5B983F')
    16. package() {
    17.         cd "$srcdir"
    18.         msg2 'Installing Nuclei OpenOCD'
    19.         install -dm755 "${pkgdir}/opt/nuclei/NucleiStudio/toolchain"
    20.         tar zxf "nuclei-openocd-${pkgver}-15-linux-x64.tgz"
    21.         mv "Nuclei/openocd" "${pkgdir}/opt/nuclei"
    22.         ln -sf "/opt/nuclei/openocd/0.10.0-15" "${pkgdir}/opt/nuclei/NucleiStudio/toolchain/openocd"
    23. }
    24. #
    25. # makepkg --printsrcinfo > .SRCINFO
    26. #
    27. # vim: set ts=8 sw=8 tw=0 noet:
    界面预览,会自动依赖 JLink 并自动安装 JLink 和全局 JLink 识别。
    其他 Linux 发行版本可以参考 PKGBUILD 中的打包操作进行相应的移植。
    GMT+8, 2026-7-6 02:20 , Processed in 0.324899 second(s), 36 queries .
