查看: 1360|回复: 0
The GNU MCU Eclipse RISC-V Embedded GCC build
    发表于 2020-8-23 12:04:57 | 显示全部楼层 |阅读模式
    GNU MCU Eclipse RISC-V Embedded GCC - the build scripts
    These are the scripts and additional files required to build the GNU MCU Eclipse RISC-V Embedded GCC.
    The build scripts use the xPack Build Box (XBB), a set of elaborate build environments based on GCC 7.2 (Docker containers for GNU/Linux and Windows or a custom HomeBrew for MacOS).
    https://github.com/gnu-mcu-eclipse/riscv-none-gcc-build
    GMT+8, 2026-4-30 20:01 , Processed in 0.318742 second(s), 34 queries .
