查看: 1339|回复: 0
Rocket - spec - RISC-V规范整理
    发表于 2020-8-24 11:40:48 | 显示全部楼层 |阅读模式
    根据RISC-V规范整理的几个文档。
    国内芯片技术交流-Rocket - spec - RISC-V规范整理risc-v单片机中文社区(1)
    1. 原文链接
    https://riscv.org/specifications/
    https://riscv.org/specifications/privileged-isa/
    2. Definitions, acronyms and abbreviations
    https://docs.qq.com/sheet/DUVBNaEVCUWxwV1Bi?tab=ox0pnu
    3. User-Level ISA
    https://docs.qq.com/sheet/DUURFZHNJZ0tFbVFJ?tab=tnsf3g
    4. Assembly Programmer's Handbook
    https://docs.qq.com/sheet/DUVpLQWdBSlpXdG12?tab=tnsf3g
    5. CSRs
    https://docs.qq.com/sheet/DUURQVEFJVmdOcVZI?tab=tnsf3g
    6. Privileged Instructions
    https://docs.qq.com/sheet/DUWFNcFFPVXFEVm9X?tab=hrpw36
    7. Introduction
    摘录自The RISC-V Instruction Set Manual Volume I: User-Level ISA, Chapter 1:
    RISC-V (pronounced \risk-ve") is a new instruction set architecture (ISA) that was originally designed to support computer architecture research and education, but which we now hope will also become a standard free and open architecture for industry implementations. Our goals in dening RISC-V include:
    • A completely open ISA that is freely available to academia and industry.
    • A real ISA suitable for direct native hardware implementation, not just simulation or binary translation.
    • An ISA that avoids \over-architecting" for a particular microarchitecture style (e.g., microcoded, in-order, decoupled, out-of-order) or implementation technology (e.g., full-custom, ASIC, FPGA), but which allows ecient implementation in any of these.
    • An ISA separated into a small base integer ISA, usable by itself as a base for customized accelerators or for educational purposes, and optional standard extensions, to support general-purpose software development.
    • Support for the revised 2008 IEEE-754 foating-point standard [14].
    • An ISA supporting extensive user-level ISA extensions and specialized variants.
    • Both 32-bit and 64-bit address space variants for applications, operating system kernels, and hardware implementations.
    • An ISA with support for highly-parallel multicore or manycore implementations, including heterogeneous multiprocessors.
    • Optional variable-length instructions to both expand available instruction encoding space and to support an optional dense instruction encoding for improved performance, static code size, and energy efficiency.
    • A fully virtualizable ISA to ease hypervisor development.
    • An ISA that simplies experiments with new supervisor-level and hypervisor-level ISA designs.
    上一篇:RISC-V 开源 IP 大全
    下一篇:risc-v 汇编函数与C语言函数相互调用
    GMT+8, 2025-1-10 22:59 , Processed in 0.332610 second(s), 48 queries .
